With spray. which lifters. ls7 comp, cts
with a 636 hyd lift cam and 200 shot which lifters do you guys recommend.
was told by a friend of mine to use the ls7 over the comp oem
I have not used the 7's the caddies were supposed to be the c5-r race team designed lifters. there pretty cheep so if guys can't aford morels we get them caddys. have not had an issue with them yet. but mine was at 8400 on a 400 shot so i know the morells work. atv znged his to 8000+ a few times also.
I have had both caddy and ls7... at 1st i had the ls7's i borke the roller on one of em'... so i just installed the caddys and the caddys are a different design.. the body is different. so far so good for the caddys, but ive only had em' done for a day or so.. my cam is a 647 lift hyd roller comp cam... the caddys are quiet no sewing machine noise here.
ill take a pic of the destroyed ls7 lifter and post it on here later on tonight...
fyi.. there is a reason why the ls7 is the stock replacement lifter... it sux... go caddy or morel...
