Real Fast Question!!help Me Out!!!
Im in the process of istalling a zex nit. kit on a 2000 ws6 and im kinnda at a stand still. it says in the directions that straight out of the NMU (nitrous managment unit) the white wire needs to run to the output voltage lead from the throttle position sensor. WHAT?!?!?!?! this may be an extremly easy question. i dont know maybe im just having a brain fart. any thoughts or recommendations would be great. thanks guys
i think your looking for a tps signal. i believe its pin 10 on the ecu or the dark blue wire at the tps sensor. do a search and make sure but im sure others will correct me if im wrong
