Notices
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
2 Brand new Cuetec Python pool cues
Old 01-01-2009, 10:04 PM
BatmobileSS's Avatar
Default 2 Brand new Cuetec Python pool cues
They are both brand new cues and have never been used. One has Irish linen grip (19oz) and the other is a softec grip (20oz).
Some information from the manufacturer.
The Python duo-composite shaft is constructed by surrounding a graphite core truss rod with 4 pieces of hand selected, computer cut Canadian maple. 5 layers of fiberglass are power bonded to the wood creating the ultimate cue shaft.
- Graphite core reduces cue ball deflection
- Graphite core provides increased power
- Graphite core drives harder & sharper for better draws and spins
- 15-1/2" Pro Taper prevents the shaft from climbing up your bridge
- 15-1/2" Pro Taper enables you to reach for longer shots
- The power bonded fiberglass increases radial consistency
- The power bonded fiberglass prevents dings and dents
- Multi-layered pig skin tip Polycarbonate ferrule
- High-Tech 15-1/2" Maple shaft with graphite core reinforced with fiberglass on the outside
- Exclusive Tru-Glide finish Polished stainless steel joint
- Genuine Inlaid Designs
- Rubber bumper accepts the patented Cuetec Smart Extension
- Adjustable weight bolt system
I will sell separate for $175 + shipping each. If you buy both I will throw in a case
Quick Reply: 2 Brand new Cuetec Python pool cues
