Stereo Stuff FS. Focal,JL Audio 500/5, 8W7, 6X9
Ive got quite a few stereo Items left over for sale.
Focal Access 130 A1 Component speaker system
includes two 5-1/4" woofers, 2 tweeters, 2 external crossovers, and 2 woofer grilles
humidity-resistant, woven glass-fiber woofer in non-resonant ABS/fiberglass basket
butyl rubber surround
1" aluminum inverted dome tweeter
external crossover with 3-position tweeter level
4-ohm impedance
6-50 watts RMS power range (100 watts peak)
frequency response: 65-20,000 Hz
sensitivity: 91 dB
mounting depth: 2-3/16"
Box still sealed.
ASKING $200 shipped
Focal Access 165 CA1
2-way 6-3/4" speakers (pair)
4-ohm impedance
2-60 watts RMS power range (120 watts peak)
frequency response: 60-20,000 Hz
sensitivity: 92 dB
depth: 2-9/16"
ASKING $90 Shipped
Pioneer TS-A6964R
6x9" 3-way car speakers (pair)
mica-injected polypropylene woofer with elastic polymer surround
3/8" Mylar balanced dome tweeter
2-1/4" cone midrange
power range: 2-40 watts RMS (400 watts peak power)
frequency response: 31-37,000 Hz
sensitivity: 91 dB
top-mount depth: 2-7/8"
grilles included
Still Sealed. Never opened.
Asking $60 Shipped
JL Audio 500/5 Amplifier.
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
ASKING $300 shipped Heavy 22lbs.
JL Audio 8W7
8" Single 3 Ohm W7 Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Recommended Power Range: 150-500 watts
Impedance: Single 3 ohm
OverRoll Surround
W-Cone
Floating-Cone Attach Method
Plateau-Reinforced Spider Attachment
Radially Cross-Drilled Pole Piece
Massive Forced-Air-Cooled Aluminum Alloy Frame
Highly Linear, DMA-Optimized Motor System
Huge Diameter, Progressive Roll Spider
Co-Extruded Double Lead Wires
Changed my mind.
PM me for more details.
Kyle
4-ohm impedance
sensitivity: 91 dB
Box still sealed.
ASKING $200 shipped
4-ohm impedance
sensitivity: 92 dB
depth: 2-9/16"
ASKING $90 Shipped
Pioneer TS-A6964R
sensitivity: 91 dB
grilles included
Asking $60 Shipped
Specifications:
Features:
JL Audio 8W7
Power Handling:
Peak: 1000 watts
RMS: 500 watts
OverRoll Surround
W-Cone
Changed my mind.
Kyle
