Notices
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
FS: Eastwood TIG Welder 200 Amp AC/DC
Old 06-08-2016, 12:10 AM
l4248402t's Avatar
Default FS: Eastwood TIG Welder 200 Amp AC/DC
I have a brand new Eastwood TIG200 AC/DC Welder. I bought it for my brother but he never use it he keep using mine instead. I paid $750 for this one and now Eastwood have it listed on their website for $699.99. . Just trying to recoup as much as I can at a reasonable price so I buy more parts for my project car.
Details from Eastwood website:
About Eastwood TIG Welder 200 Amp AC/DC
Eastwood TIG200 200AMP welder features an AC/DC switch that allows both steels and aluminum to be welded with the same machine. With a 14' torch and a 10' ground cable, you'll be able to get into any space with this exceptional welding machine. It has pre- and post-flow adjustment ***** to protect your weld and torch. It even has a foot pedal to control amperage so you can get going quickly, without the need to dial-in the machine for a specific material. Powered through a NEMA50 plug.
Automatically switches from 110v to 220v depending on input. Infinitely adjustable foot pedal and amperage control allow accurate aluminum welding, and adjustable pre- and post-gas flow results in proper arc starting, stabilization and bead cool-down. Thumb control overrides the foot pedal for out-of-position welding, or when bench welding is not an option.
Contents
TIG200 Unit
Shielding Gas Regulator
Shielding Gas Hose
Ground Cable with Clamp, 10'
TIG Torch (17 Series), 14'
Foot Pedal for Amperage Control
110v-to-200v Adapter Plug
Instruction Manual
Handheld Shield
Hammer/Brush
#7 Cup (7/16"), #6 Cup (3/8"), #5 Cup (5/16")
Long Back Cap, Short Back Cap
3/32" Collet Body, 3/32" Collet, 1/16" Collet, 2.0mm Collet
Thoriated Tungsten (2.0mm Red)
Specs
Input Voltage: Single-Phase 110vAC or 220vAC (±15%) @ 50-60Hz
Input Amperage: 28 amps
Output Amperage: 10-200 amps AC/DC
No-Load Voltage: 51
AC Duty Cycle (%): 20-80 (80% at 100 amps, 20% at 200 amps)
Post Gas Flow: 2-8 sec.
Pre Gas Flow: 0.1-1.0 sec.
Remote Foot Pedal And Control: Yes
Efficiency: 80%
Cleaning/clearance effect (AC balance control) is adjustable to provide wider cleaning with shallow penetration to narrow cleaning with deeper penetration. Changing electrode from EN (electrode negative) to EP (electrode positive).
Frequency is fixed at 60Hz, which provides a little wider bead but with good penetration for aluminum and magnesium.
Inverter and MOSFET technology offer optimum performance at a very affordable price.
Attached Thumbnails FS: Eastwood TIG Welder 200 Amp AC/DC-0607162146.jpg   FS: Eastwood TIG Welder 200 Amp AC/DC-0607162146a.jpg
Old 06-10-2016, 12:22 PM
l4248402t's Avatar
SOLD, Thanks for looking
Quick Reply: FS: Eastwood TIG Welder 200 Amp AC/DC
