FS: Dell 17" LCD Flat Panel Monitor
FS: Dell 17" LCD Flat Panel Monitor..price lowered!!
This is an excellent Dell monitor, model# E176FP, that has less than 20 hours use. Monitor has a 12ms response time making it great for playing games or watching movies. Below are the Tech Specs taken from the Dell website. If you need/want more tech specs, just run a google search on the model number. Or click:
http://www.google.com/search?hl=en&lr=&q=dell+E176fp
I am looking to get $130 plus shipping. Contact me with any questions that you may have and I will be glad to answer them. Thanks.
Here is a stock photo:
Tech Specs
UltraSharp Display
No
Monitor Size
17" Flat Panel LCD
Viewable Image Size (VIS)
17.0"
Monitor Type
Active matrix - TFT LCD
Pixel Pitch
0.264 mm
Response time
Typical 12 ms
Brightness
300 cd/m2 typical
Contrast Ratio
450 to 1
Horizontal Viewing Angle
Typical +/- 70°
Video Input Connector Type
Analog RGB
Height adjustable stand
No
USB
No
AS501 AP compatible
Yes
Panel pivot rotation
No
Horizontal scan range
31 - 81 kHz
Vertical scan range
56 - 76 Hz
Dimensions (inches)
H: 14.95"
W: 14.75"
D: 5.4"
Weight
8.8 lb only monitor
Tech Specs
UltraSharp Display
No
Monitor Size
17" Flat Panel LCD
17.0"
Monitor Type
Pixel Pitch
0.264 mm
Response time
Typical 12 ms
Brightness
300 cd/m2 typical
Contrast Ratio
450 to 1
Typical +/- 70°
Analog RGB
No
USB
No
AS501 AP compatible
Yes
No
31 - 81 kHz
Vertical scan range
56 - 76 Hz
Dimensions (inches)
H: 14.95"
W: 14.75"
D: 5.4"
Weight
8.8 lb only monitor
