Northwest Members WA, OR, ID, MT, WY, SD, ND
Ellis, I need to setup a clutch replacement appointment!!
Old 04-13-2006, 05:10 PM
ram-it's Avatar
Default Ellis, I need to setup a clutch replacement appointment!!
I will be getting the LS7 clutch. What part do I need for the quick clutch fluid drain? In order to make sure I get all the right parts can you give me a shopping list? I also need your number.
Thanks!
I hope this did not violate any form rules.
Old 04-13-2006, 06:02 PM
ram-it's Avatar
Here are the GM parts that I am looking at. Anything I should add? http://forums.corvetteforum.com/show....php?t=1363214
Old 04-13-2006, 06:54 PM
TwoFast4Lv's Avatar
shoot me a call
Old 04-13-2006, 07:20 PM
98ls1/87vortectpi's Avatar
not to just jump in here, i would like to have some work done as well; can you pm me your number i cant seem to find it anywhere.. thanks
Old 04-13-2006, 07:56 PM
pro1955's Avatar
I just did mine, you need the clutch set up with flywheel, you already have the master and slave cyls. Be sure to install a remote bleeder hose, bought mine from LAPD, I checked the balance of my clutch it was off 25 grams. I installed DTE strut brace and tunnel plate just because thats the time to do it, I have done several holeshots, gear slams no problems with sticking clutch pedal, slipping ect. will take to track soon.
Old 04-21-2006, 11:27 PM
ram-it's Avatar
Ellis, I bought the LS7 clutch kit plus the Z06 slave and master cylinders, pilot bearing and remote bleeder. Stuff is shipping regular ground and will be here next week. Will call you as soon as I get it.
Quick Reply: Ellis, I need to setup a clutch replacement appointment!!
