sail pannel triangle trim
Old 06-29-2014, 02:50 PM
SS_TOR's Avatar
Default sail pannel triangle trim
One of my sail triangle trim pieces is cracked so I found a replacement one. Im assuming I can just pry the busted one off but how do I go about securing the new one on there though. Will it just snap in place or should I use some sort of adhesive?
Old 06-29-2014, 05:50 PM
RedDeadG8's Avatar
you can try a heat gun around the edges and work some dental floss behind it to get it off. I wouldnt pry. My replacement pieces had a 3m adhesive already on the back, just had to pull the tape backing off and stick it on.
Old 06-29-2014, 06:17 PM
SS_TOR's Avatar
ahhh a heat gun good advice. my replacement piece doesnt have 3m adhesive on it so I'll just get some double sided 3m and put it on. thanks!
Quick Reply: sail pannel triangle trim
