**** 4th gen Trans Am Ultimate Restoration ****
Old 04-23-2016, 06:44 PM
  #81
2JAWZ's Avatar
This is just always getting better and better**
Old 04-23-2016, 10:39 PM
  #82
96famaro's Avatar
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
thank you sir!
Old 04-24-2016, 01:55 PM
  #83
96famaro's Avatar
Blower piping.
Aeromotive regulator 1 : 1 ratio
Doing something a little different.
ARP studs, ATI damper, Big Block Hub, Cloyes double chain.
T.P.I.S. timing cover, and 24x connection diy kit.
Finished engine wiring for 24x conversion.
Coil wiring.
Double fuel pump wiring harness with hobs switch.
Ultra magnum roller rockers 1:6
Spec stage 3+ clutch
-6an return weld bung to fuel rail.
Modified lower pipe and added upper bridge pipe in front of fuel rail.
Threaded I.A.T. sensor. I may go with a metal sensor though.
Old 04-24-2016, 02:22 PM
  #84
96famaro's Avatar
F1r blower
Nice machineing.
F1r next to p1sc comparison.
Ported Trick Flow heads and Intake
Heavy duty piece.
12 rib 7.65 crank pulley with machined spacer.
Drilled out 3 more bolt holes.
Canton oil pan installed and I add the right stuff sealant. Hands down best stuff for sealant that I know of. I'm saying this from experience.
Bracket I built for additional strength for the blower to keep flexing minimal.
Bolts onto front of block and the side. Really hard to get a good picture of it.
Here's the top additional bracket. I'm going to redo this to some more heavy duty steel. At the time of doing this one I ran out of steel and not happy with it but that will be later once I finish other stuff first.
Old 04-25-2016, 02:24 AM
  #85
96famaro's Avatar
Custom built inlet blower pipe.
Procharger's stock hat vs mine.
Old 04-26-2016, 12:54 AM
  #86
enigmah's Avatar
Damn thats some sick custom work man, keep it up and us updated! I want to see this beast when its complete!
Old 04-26-2016, 12:45 PM
  #87
96famaro's Avatar
Thank you. It's getting really close. I basically already finished all of the car now. I'm just lacking headgaskets and doing a few other mods to it. I keep updates flowing.
Old 04-26-2016, 11:32 PM
  #88
96famaro's Avatar
Just a little teaser pic.just finished spraying the bumper today. Body gaps are measured exactly 4mm or 0.15 inch tolerance all around the car. Hood to fender, headlight lens to bumper, bumper to hood etc. These cars never line up and neither did this build. I'll show you all how I do it, most people freak when they see the work process on their vehicles but I always say, it's gotta get worse before it gets better. Anyways, I'll keep my talk to a minimum and let my work do the talking. Stay tuned final unveil
Is right around the corner.
Old 04-27-2016, 01:05 AM
  #89
96famaro's Avatar
Default 7u
Some nice finish touches IN my opinion.
60 smd for rear taillights. I'll be putting switch back bulbs for the front turn signals.
New signal/Parking housing.
Electronic flasher
I'll be using 9005 and 9006 L.E.D. bulbs for my headlights. 12,000 lumens for high beams and gonna try using 2,000 lumen low beams. If anyone may have some knowledge in knowing where I can find projector beam housings for this car that would be great.
Old 04-27-2016, 08:56 AM
  #90
ss4chad's Avatar
Impressive!
Chad
Old 04-27-2016, 11:03 AM
  #91
BSmiff's Avatar
I got to the end of the pics and got sad
Old 04-28-2016, 08:44 AM
  #92
RidetechJosh's Avatar
Crazy...
Old 05-03-2016, 12:55 AM
  #93
96famaro's Avatar
Mock up stage for front end.
Gaps are off pretty good.
I always remove all paint around letters so it don't look distorted from paint stacking.
Passenger side.
It's got to look worse before it looks better.
That's more like it. Perfect body gaps.
Old 05-03-2016, 01:05 AM
  #94
96famaro's Avatar
Going to look alright.
Old 05-03-2016, 12:16 PM
  #95
BSmiff's Avatar
WOW. Looking good in there for sure. That color is going to look nasty on a bird.
Old 05-03-2016, 06:38 PM
  #96
enigmah's Avatar
That attention to detail tho
Old 05-04-2016, 11:27 AM
  #97
HappySalesman's Avatar
Damn. I'd love to learn how to mud like that. Fix most of the panel gap issues on my car lol.
Old 05-05-2016, 06:05 AM
  #98
1RawTA's Avatar
Very very impressive.
1. Do you sleep?
2. how many people work for you
lmao!!!
Old 05-08-2016, 09:52 PM
  #99
96famaro's Avatar
Anyone up for engine spoiler pic? Or should I wait till I get it 100% to show off?
Old 05-08-2016, 10:18 PM
  #100
scj
scj's Avatar
Quick Reply: **** 4th gen Trans Am Ultimate Restoration ****
