Who has cut away/replaced the quarter panels?
My quarters are messed up and instead of cutting/welding in a new one is it possible to cut the old away and kinda reinforce it "space" frame style then have new quarters made that are made like the fenders/rest of the car so no more worry of quarter damage/hail/flex/etc?
I would imagine it's reasonable to cut out the quarter, leaving a flange to glue on a composite fender, weld in a flat section (maybe with ribs) to seal up the gaping hole so there is still a solid structure there and then use a urethane to "glue" on a composite copy of the fender to the flange that was earlier left.
I would guess that you would not loose any structural stability with this method... I don't know for sure though.
Bodyman, assuming someone was willing to go through all the extra work would my solution be adequate from a structural standpoint?
I ask mostly out of extremely morbid curiosity.
