Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Comp cams dual valve springs .675" lift 26926ts-kit
Old 05-18-2014, 09:39 PM
bcbosley's Avatar
Default Comp cams dual valve springs .675" lift 26926ts-kit
Category: Accessories
Price: $350
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): OH
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block
LS Engine?: Fits LS Engine
This a brand new set of dual valve springs that I removed from a brand new set of heads I bought. The engine builder who I bought the heads from, assembled the bare heads using these springs. I removed the springs only because I needed more spring pressure and higher lift for my application. These springs are good for .675" lift! The spring locators were machined slightly by the engine builder to help clear valve stem seals on some applications with bronze guides, such as mine, but will not affect their operation. You will need to purchase valve stem seals, as I had to remove them to get the springs off. Included as well are a variety of shims to get proper install height for your set-up.
COMP Cams 26926TS-KIT - Comp Cams Dual Valve Springs Details
1.320'' Outside Diameter Dual Valve Springs
This Dual Valve Spring Kit for LS engines includes carefully matched Dual Valve Springs, lightweight tool steel retainers, 7° locks, seals and spring seats. With a .675'' maximum lift, these COMP Cams Dual Valve Springs for race applications are manufactured from Super Clean wire and subject to extensive quality control testing to deliver a valve spring assembly with superior strength, durability and valve train stability, no matter the application. The dual spring design creates a stronger valve spring that can easily handle the increased lift found in extreme stress applications. COMP Cams Dual Valve Springs exceed the expectations of today's engine builders and racers.
249-26926-16 Street/Strip Dual Valve Springs
249-1779-16 Tool Steel Retainers
249-623-16 7° Steel Valve Locks
249-4695-16 Spring Seats
Ideal for street/strip hydraulic roller, some solid roller and some solid flat tappet rac
Attached Thumbnails Comp cams dual valve springs .675" lift 26926ts-kit-imag0486.jpg   Comp cams dual valve springs .675" lift 26926ts-kit-imag0490.jpg   Comp cams dual valve springs .675" lift 26926ts-kit-imag0487.jpg   Comp cams dual valve springs .675" lift 26926ts-kit-imag0488.jpg   Comp cams dual valve springs .675" lift 26926ts-kit-imag0489.jpg
Old 05-19-2014, 08:54 AM
bcbosley's Avatar
$350 shipped
Old 05-19-2014, 01:16 PM
bcbosley's Avatar
This is a deal for these springs!
Quick Reply: Comp cams dual valve springs .675" lift 26926ts-kit
