GTO 3.90 Diff, Driveshaft, ATI Damper, Lonnies GTO Fuel Kit, LS3 Intake, MSD Light
Category: Accessories
Price: $1300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): NC
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Thanks!
-2004-2006 GTO differential built with a Detroit posi, Motive 3.90 gears, and Gforce 1320 billet 1350 pinion flange, WITH DRIVESHAFT. A 3" ballanced steel driveshaft is included that has 1350 u - joints on both ends. All you will need for installation is a transmission yoke of your choice. This differential has very little use, the fluid drained shows almost no signs of wear and looks practically new. $1300.00 Shipped.
-Pontiac GTO and F Body ATI super damper balancer removed from a 2006 GTO with 25,103 original miles on the odometer. This balancer is in good condition and ready to use. $290.00 Shipped.
-Lonnies double pumper fuel system for the 2004-2006 Pontiac GTO, removed from a 2006 GTO with 25,103 miles. This system is complete, the only thing you may need is possibly small NPT plugs (if you are not using gauges for fuel pressure or boost). This system will support 1000 RWHP on gasoline with no other modifications. This system comes with a modified stock fuel bucket that drops in the factory full tank using the stock connection. It utilizes two Walbro 255lph fuel pumps. One is on all the time for regular driving, the other is boost activated by the hobs switch. You can also make this system activate with rpm or nitrous. This is a true plug and play kit.
Kit contents:
DROP IN MODIFIED STOCK BUCKET WITH TWIN PUMPS,
-8 TEFLON SUPPLY LINES,
-6 TEFLON RETURN LINES,
-BILLET FUEL RAILS,
-FUEL LABS REGULATOR,
FUEL FILTER,
PLUG AND PLAY WIRING HARNESS TO THE STOCK TANK,
HOBS SWITCH
$1300.00 Shipped
-LS3 Intake Manifold- Great shape, comes with all intake gaskets and TB gasket. Not sure what type of MAF but I will leave it in there.
$200.00 Shipped.
-MSD Shift Light Programmable Digital 89631
$90.00 Shipped.
