TCI, Yella Terra, COMP CAMS, 243 heads, Fuel Rails, BMR,
Category: Accessories
Price: $150
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Tci 399753 SFI Flexplate like new paint is still on the teeth. $200 shipped
Yella terra shaft mount rockers #6614 1.8 ratio ls1 BNIB $500 shipped
NX Progressive Nitrous controller 150 shipped
XR288 Comp cams 3 bolt 236/242 580/590 112 lsa $250 shipped
TR224 CAM 562/562 224/224 112 lsa $300 shipped
Comp Cams 54-444-11 XE-R LOBES 581/588. 224/230 114 lsa $300 shipped
New never installed Solid Double adjustable LCA'S and solid double adjustable panhard bar with rod ends and bushings 260 shipped
Off road y- pipe I believe it's 3.5" with cut out $85 plus shipping.
02 camaro as cluster unsure of exact mileage but should be less than 100k $70 shipped
03 z06 fuel rail single line 100 shipped
2002 camaro SS. Leather door panels no rips , DS (pictured) has spot on armrest only issue I can remember. 150 shipped for pr
243 heads Fresh from machine shop Performance valve job and milled .003 ready to bolt on like new 600 shipped
LS3 Water Pump off of 2010 ss camaro 10miles 100 shipped
4 corner coolant crossover 35 shipped
gen iv floating bushed rods reconditioned 110 shipped
5.3l HO flat top pistons on floating rods 175 shipped
ls1/ls6 throttle cable bracket w/ bolts 30 shipped
lq9/lq4 Iron Block Gen III Bored .030 new plugs and cam bearings
fresh from machine shop ready to assemble like new $650 we can discuss shipping from 65622 but local p/u or can possibly meet preferred
78mm nos ls1 plate 75 shipped
Everything is in Very good condition unless stated in description
We have several engine parts for ls engines available if you dont see it ask.. Any questions ask can call or text at 417seven33-6707 or pm
Thanks
