LS1 Engine Complete With SSP Wiring Harness and Accessories Conversion Project Ready
Category: Engine - Complete Motors
Price: $4000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): CA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
This is an LS1 with an LS6 block (better cooling) see pictures for P/N. This is the way they came in the later 2003 Corvettes and some of the Camaro's and Firebirds.
- Brand new LS6 intake
- Brand new 243 heads.
- New Thunder Racing "cheatR v.3 LSx Cam 219/230 .607"/.604" 117 LSA
- New CompCams Pushrods
- New CompCams Double Valve Springs
- New CompCams Steel Retainers
- New CompCams Spring Seats
- New Delphi / Bosch Injectors
- New Bosch Platinum Plugs
- New Turn One P/S Pump (this has been valved for the Porsche 944 rack)
- All New Sensors including knock sensors in the valley.
- New timing gear
- New Water Pump and Modified for second temperature sender (one for PCM and one for the dash)
- New Moroso Modified Oil Pan. This mod is specifically for the 944 but will still work as intended. If you do not want it, I will keep it and knock a few bucks off the price.
- New Oil Pickup
- Ported and Polished Throttle Body
- Ported and Polished MAF Housing
- Brand New Sand and Street Performance, Inc. Wiring Harness (I have an original from a 2001 T/A that you can have also)
- PCM With HP Tuners Base Tune
- Used Coil Packs
- Used Spark Plug Wires
- Stock Camaro exhaust manifolds and catalytic converters.
- BNIB Starter
- BNIB Compressor
- BNIB Accumulator
- BNIB Alternator
- New Throttle Cable
- New Dipstick Tube and Dipstick
Pictures can be found here (there are lots, too many to post up on the board): https://www.dropbox.com/sh/007u9btul...6dmb57bsa?dl=0
I am located in the Sacramento, California area. I can not ship this. I am asking $4000 for everything.
