NEED SOME ADVICE ABOUT O2's
Only at wide open throttle i get codes p0131 and p0151 which is circuit low voltage for both front oxygen sensors. the other day when we had a 50 degree morning it threw a p0135 code quickly after start up, which is oxygen sensor heater malfunction for front driver side. Today when i started it up an went down road it had some stuttering or hesitation whatever you want to call it, and after i warmed up it was fine and did not throw a code. The big question is will new O2's fix this and if so which brand should i go with????
thanks for any help and advice
