ABS INOP, ARS, Low Trac.....
I've searched many threads and can't seem to find the answer to my problem.
Since I swapped my stock 10 bolt out for a Midwest 9" I've had issues with the ABS INOP, Brake, Low Trac and ARS lights coming on... The problem is intermittent... sometimes they come on... but then they go off.... weird.
I have a 4 channel ABS system.... and the sensors were simply moved from the stock rear over to the Midwest 9".
I've tried looking at my DTCs... but I don't see anything ABS related.... I do have something about a steering sensor....?
My question is, how do I use HP Tuners to help me figure this issue out? Does HPT scan/record wheel speeds? Please help.... Thanks
**** DTCs Attached ****
Found it
I found a great thread with the information and diagnosis I was looking for.
https://ls1tech.com/forums/showthrea...ighlight=c0046
I'll post my DTCs here so that in the future if anyone is searching for a fix to this same issue this thread will show up.
[Brake] C0046 - Brake Pressure Sensor A/B (History)
[Brake] C0051 - Steering Wheel Position Sensor (Current)
[Brake] C0245 - Wheel Speed Sensor Frequency Error (History)
I'll update this thread after I have this issue fixed.
