02s at 950, where do they need to be?
Old 09-20-2003, 12:17 AM
quickWS6's Avatar
Default 02s at 950, where do they need to be?
My 02s are about 950 at WOT, I understand they should be somewhere between 850-950, with 850 being the lean area, right? What do I need to do in the Injector tables to lean it out a little? Thanks!
Old 09-20-2003, 06:52 AM
Moderator
JNorris's Avatar
Default Re: 02s at 950, where do they need to be?
I would not mess with the IFR table for this. IF you want to change your WOT fueling you need to lower the Power Enrichment (PE vs RPM) table.
John
Old 09-20-2003, 08:16 AM
TILEMAN's Avatar
Definately lower the PE table.
Old 09-20-2003, 09:35 AM
StevieZ's Avatar
.950 may be OK depending on several factors. Air temp, heat soak and several other factors can change your O2 sensor voltages quite a bit. I wouldn't bother adjusting it unless you're on a dyno and really know where your AF is.
