Freakin COdes
Freakin COdes
i have lt's with or-x pipe and borla xr-1s with a 45deg turn-down. i keep popping a p1133 code...i did find a small exhaust leak in my header collector, i just repaired it with new soft alum gaskets and then sealed them with high temp copper sil. so theres no more exhaust leak..now...will i always pop that code because i have no cats? my rear o2s were deleted as well...
Are you using extensions? Bank 1 Sensor 1 would be the driver side 1st 02 sensor... Check your sensor grounds, or for burnt wires. doesnt neccisarily(sp*) have to be an exhaust leak...
-Mark
-Mark
well thats the thing. i just moved to tucson az. and i dont know any tuners...so i dont know how to change any of the o2 switch tables..is there anyone perferes in my area?? i dont mind driving a ways either..i was told there were a couple in phoenix??
