What injector flow rate and injector offset to use?
Re: What injector flow rate and injector offset to use?
With Ford 30 SVos?
Got a car with a numbers I came up with for flow rate but the ltrims are maxed out positive wondering if i have the right numbers
joel
Ford SVO's are actually rated at 43.5 psi, so their lb/hr is slightly higher for our fuel pressure
Ford SVO = 30 lb/hr * SQRT (58 psi / 43.5 psi)
Ford SVO = 34.6 lb/hr
With that being said the ratio math ends up being.
34/26 = 1.30 or 130%
115% will still work but you will be a little rich at first.
Good Luck
Good Luck
