Bench Tune 5.3??
Old 12-31-2008, 04:41 PM
Ellis Juan's Avatar
Default Bench Tune 5.3??
Im just finishing up my frame off rebuild of my 76 vette. Swapping in an lm4 and t56. I have a friend who lives a few hours away that has hp tuners and was gonna give me the rest of his credits so he could tune my ECU. What do I need to bench tune? That way I could just take my ecu up to him. I have the complete wiring harness that speartech re did. What would be the easiest route?
Old 12-31-2008, 06:35 PM
poconojoe's Avatar
Do a search for a bench harness and make one.
Basicly you'll need the blue PCM connector
OBD2 connector
12 volt power supply
Switch to turn ignition power off and on
Old 01-01-2009, 04:37 PM
Ellis Juan's Avatar
Bench harnesses are for when the car isnt available. Well I have the entire engine harness. My harness has an OBDII connector the blue pcm connector and a check engine light.Its out of the car, so couldnt I just put an on/off switch between the power supply and the harness?
Old 01-01-2009, 06:50 PM
EARTH MOTORS's Avatar
hey,hook up batt pos and neg to harnes ,pos to ign wire ,HPTuners to ob2 conector your good to flash, that is how I test harrness and pcm funtions on harnnes i redo for swaps JIM
Old 01-01-2009, 06:53 PM
Ellis Juan's Avatar
Thats kinda what I was thinking. I just didnt want to drive a few hours and find that it wouldnt work. So Ill just take my harness and ecu up. Thanks for the responses.
Quick Reply: Bench Tune 5.3??
