Why is my timing at 0?
I posted this question in another thread on efilive and I wanted to ask here also.
My log and tune can be found here:
http://forum.efilive.com/showthread.php?t=9818
In my log between 16740 and 16760 my timing drops to 0 with no KR recorded and the commanded timing is 35*... What table is causing this? And is this normal? It's causing my AFR to lean WAY out so I wouldn't think that it's a good thing.
Thanks!
Jeremy
Thanks!
Jeremy
I followed the directions in the AutoVE doc for disabling DFCO.
BTW - What is DFCO?
What it's doing is randomly nailing 0-10* timing when I let the TP fall to 0%. Then just after the timing drops the AFR jumps to 30-45%.
BTW - What is DFCO?
Found it - The AutoVE doc says to set B3313 to 122c but it looks like B3308 has to be set to 122c for M6 cars. I just went through the directions and didn't look at the other tables the first time around.
