Need help with my tune
Old 01-19-2009, 08:48 PM
evilbeef54's Avatar
Default Need help with my tune
wondering if someone can talk a look at my tune on my 94 camaro, it is done with tunercats and i have some wideband logs (although the RPM's read about 1000 higher than accurate i still have to fix that, lol) i'm still trying to find the cause of my split BLM's i have replaced all the plugs, there is only one tiny exhaust leak but it is after the o2 sensors so i dont think that is the problem, i cant find any intake leaks, i put in new AC Delco 02 sensors, although i didn't pull the battery for 10 min after doing it to reset the blms. I accidently fried my PCM and will be getting a new one tomorrow so i'd love to see if anyone has any advice for my tune before i flash it to the new PCM.
.bin (tune file) and datamaster files from the races, the first 3 races were motor only, files 4 and 5 are on the bottle, you can see the notes for changes i made
http://www.datafilehost.com/download-3d0739dd.html
wideband logs
http://www.datafilehost.com/download-e8c3054f.html
