little help with my tune
Old 01-27-2009, 12:34 PM
72chevelle6.0's Avatar
Default little help with my tune
Can someone look at my tune and see what they think? I can not get the o2's to settle and such. here is the link to my post on HPtuners
http://www.hptuners.com/forum/showthread.php?t=21874
Old 01-27-2009, 05:47 PM
edcmat-l1's Avatar
You will never get your 02s to "settle". They're meant to oscillate. Actually, the fuel trims are meant to oscillate, and the 02s reflect that.
Catalytic converters need alternating rich lean rich lean to supply the catalyst bed with alternating (high, low) levels of oxygen as well as hydrocarbons.
You're long terms are very negative.
I haven't looked at the tune yet.
Old 01-27-2009, 05:53 PM
Ok I was just watching a friends stcok truck and the o2s where pretty smooth at idle. I have tried to to the VE table tuning but the car will surge really bad is that normal?
Old 01-27-2009, 06:04 PM
edcmat-l1's Avatar
Your fuel trims are way off. I didn't look at the tune yet, but it looks as if the injector flow rate is off.
Old 01-27-2009, 06:18 PM
edcmat-l1's Avatar
Need to change your injector flow rate.
Old 01-27-2009, 08:29 PM
ok i just put in that the injector flow calc said to. Guess I should up it. I had it at about 25 at one time
