OK, misfires. *DELETED*
Re: OK, misfires.
I could see a spring if I were getting misfires on 1 cylinder but why would I be getting misfires on the other cylinders? Does 1 broken spring "virus" the others into misfires too?
ITT
ITT
Re: OK, misfires.
I'm having this same problem, except its only with the right bank, like u said in open loop, no missing, and it only seems to happen after the car is run for a while then shut off then run again, thinking its an intake leak, when I finally get the misfires accually happen, I switched (efi pro) to open loop and nothing, I think it has something to do with the o2's maybe mine are the original 98's, my ltft's for that side goes to +25 when misfire occurs
Re: OK, misfires.
I finally get the misfires accually happen, I switched (efi pro) to open loop and nothing,...
ITT
