Question about MPVI Pro interface
Hello. I have the MPVI Pro interface. I want to know if I can use this device to log a wideband controller, without being connected to an OBDII port? Basically, I want to use the VCM Scanner to view logs of a wideband O2 sensor installed on my ATV. Is this possible?
With my LM-1 wideband it came with a program called logworks and you can log it with that. If you have the AUXBOX you can also bring in a 0-5V input (and tac signal) to log RPM VS wideband o2 reading.
