Changing gear ratio, what needs to be done?
Old 03-18-2009, 01:07 PM
Blindbatts's Avatar
Default Changing gear ratio, what needs to be done?
going from whatever is stock on an `01 z28 A4, to a 3.42 rear from an M6 SS.
Car has a lid and catback, but otherwise stock.
Would a hypertech work? Or is something like an SCT required?
Looking for cheapest solution
Old 03-18-2009, 01:14 PM
Sid447's Avatar
Go to a GM dealer and ask them to adjust (correct it by changing the PPK value) with Tech 2.
Old 03-18-2009, 11:50 PM
Blindbatts's Avatar
what does this cost, and why should a dealer need to do this rather than myself with a handheld?
I switched to 4.30 gears in my 97 cobra and all I needed was a $100 speedcal that plugged inline with the VSS to recalibrate everything and it ran perfect.
Old 03-19-2009, 12:01 AM
Sid447's Avatar
You asked for the cheapest solution, did you not?
Old 03-19-2009, 12:16 AM
Blindbatts's Avatar
so it's free? Nobody has mentioned a cost yet.
Old 03-19-2009, 12:42 AM
Sid447's Avatar
If you're on good terms with your local GM Service Manager and ask nicely, I don't see why not.
(Or use your diplomatic charm and tact if not).
All you need to do is ask for it to be changed to another stock setting; the same as the M6 PPK value.
This assumes you are on the same overall diameter tyres as a stock car. As this will also affect the speedo and shift points.
