Adjusting Converter lockup with diablosport??
Old 04-18-2009, 08:19 PM
boola1341's Avatar
Default Adjusting Converter lockup with diablosport??
I've recently installed the level 2 performabuilt trans with there 3k stall.
Is it possible to adjust converter lockup with the diablosport predator?? I've noticed when taking off from a standstill the converter with lockup at 35 mph in OD then downshift on it's own to pickup speed then lock back up again once it gets around 41-43 mph. Once locked above that speed it stays locked.
Old 04-19-2009, 12:13 AM
boola1341's Avatar
Anyone here uses the predator much???
Old 04-19-2009, 09:02 AM
LS1Tech Sponsor
06MonteSS's Avatar
you can't adjust it via the predator handheld unit... you need to get a custom tune created for it, via the diablo CMR software....
post up over at the diablosport forums and they should be able to do it for ya...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 04-19-2009, 10:30 AM
boola1341's Avatar
Thanks
Old 04-19-2009, 12:35 PM
WS6Power's Avatar
Yep, I just had my lockup changed from 45mph to 50mph. It has to be changed in your tune and then installed with the Predator. And with your trans you may also want to delete TM. Car will shift better and should run a faster ET.
Old 04-19-2009, 02:47 PM
boola1341's Avatar
what do i need in order to get the tune downloaded onto the predator? Is it that cable or something else?
Quick Reply: Adjusting Converter lockup with diablosport??
