Ethanol In Gas
I run gas with ethanol all the time. I don't even know if you can buy it without around here. No problems with afr though. Maybe the tune isn't fully sorted out or a bad 02 sensor? If one bank is lean the other should be as well. Or possibly you have an air leak on that side.
