Do I need to Tune if i change plugs?
So you're just replacing your spark plugs, and you're asking if now you need
to get a dyno tune done on the car. If that correct, what you're asking?
If that is correct, why would you need a tune if you're only putting new plugs in it? Think about it, does every place that does tune-up, dyno a car after.
Just because you're switching to a different plug doesn't mean it needs a tune.
no you dont need a tune, just make sure you have them gaped properly, if you already have a tuner, just ask hm what the gap should be on your setup. when i put my plugs in (tr55) i left them at the stock gap which is .55. I dont have a tune right now on my car other then factory and im not having any issues.
dont be a dick. its just a question.
Thanks again
