Wiring harness replacement connectors?
So I'm dropping in my new motor yesterday, connecting the wiring harness back to all the sensors... and find out that someone previously cut out the old knock sensor connector on the wiring harness and hard wired the knock sensors in... and since I'm doing an L92 conversion I have to extend the knock sensors... so I've got a problem. I've got the extension hardness, but I have nowhere to plug in the vehicle side knock sensor connector.
I'm going to need to splice a knock sensor male connector back into the vehicles wiring harness.
What is the easiest way to get that knock sensor male connector? I'd prefer to buy one on-line rather than scour the junkyards. Anybody sell those around here? Thanks!
You can try here:
http://www.acdelcotechconnect.com/pi/wiring-connectors/
If you can find a part number there then you can just search ebay and other sites to find it...
You can try here:
