Help! Diagnostic code P0141???
Long story - basically, I had my clutch changed under warranty, shortly after the check engine light came on. The car ran fine and I plan on doing heads/cam and figured I would wait until I did the swap. The problem is now, I took it to get emission tested and they hooked it to the OBD computer and trouble code P0141 came up. Says, O2 sensor heater circuit malfunction (bank 1 sensor 2). Is this just a O2 sensor or something I can fix?
Tried to clear the code........comes back on. That is what I figured, they forgot to hook something back up, or maybe a bad O2 sensor.
Worst case, if that is it, I have O2 sims for the rears for the FLP's- I can always put those in for now. So the rear O2 sensor is either not plugged in or malfunctioning?
