2K rpm on the street, Iddle fin after 2 sec when I stop
Here the problem. I can start the car and it iddle fine. I can rev it and it go back to normal. On the road, in all gear the car run at 1.5-2k rpm (if I dont tuch the gas) and when I stop at a stop sing or light, it take 2sec to drop from 2k rpm to arround 800-1K rpm. It do the same thing if I but the car in neutral until I stop.
Car have ben tune whit HP tuner whit true duals, no cats and no X by the other owner. Now it have a Y pipe + hight flow cats (need to pass safty check).
You think I need to retune the car or put back the old exhaust back? (and have alot of ticket). I have no check engine light.
Car is 2001 Trans Am 6spd whit all bolt on (include head and cam)
Thanks
Thanks
I have read in other posts that the throttle follower and throttle cracker settings are responsible for this. My '71 GMC with a 411 PCM conversion does the same thing, and I am going to play with them settings and see what happens. Makes it really easy to experiment with the roadrunner PCM!!!
Mike
Mike
Mike
Mike
Good luck
Mike
