codes c1232, c1233 & c1248
Old 06-09-2009, 08:13 PM
1972bluelt1's Avatar
Default codes c1232, c1233 & c1248
My 2001 Corvette sets codes c1232h, c1233h and c1248h. DIC says service ABS, TC and AH. If I shut the car off and restart the condition returns in a mile or 2. Doesn't seem to matter if the codes are reset or not. The front wheel sensors read about 1050 ohms and .5 vac if turned. I checked this at the hubs and the 1st connector at the frame. So I don't think it's the connectors. Two rebuilders told me the EBCM cannot be repaired because it's a logic problem. Before I spend the big $ for a new module I want to be sure that will fix it. Also, can I disable these codes and dash lights? This car has 6500 miles on it, and has never seen a drop of rain. None of these systems have ever been activated.
Thank You
Quick Reply: codes c1232, c1233 & c1248
