Very Wacky Ltrim/Fueling Issue - Looking for ideas
At idle, part throttle, and WOT my Ltrims are perfectly fine and A/F is just dandy.
Let off the gas in gear though and coast and bank 1 goes to -16% but bank 2 only goes -6%, A/F richens up to 12:1 and no matter how long I wait as I coast down the car cannot recover. Tap the gas to get going again then boom the 02's go to almost zero, A/F goes to 16-17:1 then a second or less later all is normal again. O2's are even, Ltrims are even, A/F is 14.7
The byproduct is a very annoying surge as the car decides to go instantly from 12:1 to 17:1 when I give it gas again. Plus I have to think I am getting worse gas milage as well. Seeing as I drive in alot of traffic which leads to alot of off the gas, on the gas, off the gas, on the gas, the surging/bucking is extrememly annoying.
What baffles me is why there is only a descrepency at decel. If it was a vacum leak or exhaust leak or something of that nature should I not see things messed up in all situations??? IE idle, part throttle, wot, decel.....
If anybody has any theories lets hear em.
Thanks!
Thanks!
hmmm i dont know, mine do that but after a while they recover, i had a problem just not at bad as this and it was my plug wires were loose. when i let off there wasnt enough spark and one side read richer. when i was on the gas it was getting enough spark. might be something to check out..other than that just hope someone else would chime in here
