Three codes, just got my lt1 swap running.
Hey guys, im throwing three codes for my lt1. its got heads, cam, intake etc and a pcm tune from madz28. my question is when it first fired it up, had 4 codes:
P0018-injector circuit
P0022-TP sensor circuit low
P0077-fan 1 circuit
P0097-4K pulses
i pulled these codes using a tech 2.
i cleared the codes to see which ones would come back, and the only code to go away was the P0018. it hasnt come back and i still have the following codes, i understand the fan circuit code, cuz i dont have mine hooked up yet:
P0022
P0077
P0097
any help or direction to look in would be appreciated.
P0077-fan 1 circuit
P0097-4K pulses
P0022
P0077
P0097
well i found out on another forum that the 97 code is for my vss which i havent hooked my speedo up yet so thats good, my fans arent hooked up yet so that just leaves the TP code, anyone know if that just needs to be tuned out or not?
