HELP GOT A MISS FROM 800 to 1500 RPM
Got a mis from idle 800 rpms to 1500 rpms. Rev it up it seems to clear up. Once in a while it back fires at low rpms. When motor is cold the miss is not there until motor warms up then its back again. Recenly chanced plugs and plug wires. I rececked wires and plugs everything seems to be OK. We put a scanner on it and it shows nothing, no codes of any kind. Maybe a weak coil when it warms up. A chevy tech told me he does not think thats it. Its fustrating when the scanner does not tell you ****. Any ideas. Any body? Thanks
Does it happen on decel or when you throttle it?
Your software should be able to log misfires. If I am slightly rich, on decel with DFCO I get a 'normal' backfire. Is that what you are experiencing?
..WeathermanShawn..
..WeathermanShawn..
