hptuners and plx
Old 08-05-2009, 08:48 PM
massconfusion's Avatar
Default hptuners and plx
ok i just got hp tuners and i'm pulling my hair out tring to hook up the wideband. i have the bosch sensor and it is screwed in where my narrowband should be on the passenger side. it is hooked into the computer and the computer is powered up. I have one wire from the bottom right hand terminal for the analog signal to my hp inteedeerface. I called plx and they said that was the only terminal needed but i can't get a signal i'm sure i did something wronf and i did configure my histogram also. please help guys. thanks chris
Old 08-06-2009, 09:23 PM
come on i have searched this and know people are running this i just need a push in the right direction. hooked the ground from the eio to the ground on the plx the bottom left hand pin supposedly today with no help ethier
