How To Look At My Tune?
Is there a good way to look at my tune that is not real expensive?
I am not a tuner and would only get myself in trouble if I tried. I would like to look at what my tune looks like because it is a dog for the work that has been done.
By the way, what is timing normally set at (range, I know some cars can take more than others) for WOT. Here are the specs on my car:
2000 SS W/30,000 (A4)
Lingenfelter Short Block (standard bore, forged pistons at stock CR)
LS6 Intake and Ported TB
Stock Injectors
Racetronix Fuel Pump
Crane Cam 228/228 576/563 on a 114
Stage 2.5 heads from Texas Speed
Stock 10 bolt with 3:73 Motive Gears
Upgraded Trans.
3400 Stall
BMR Suspension
Weld In Sub Frame Connectors
One last question, will changing gears from a 3:23 to 3:73 after I had the car tuned cause bad performance in the tune?
Thanks for any info you can give.
Bill
Stock Injectors
Upgraded Trans.
3400 Stall
BMR Suspension
Bill
