low rpm timing?
low rpm timing?
ok in my other post i was saying i was only getting about 24-25* of timing, figured out after i got gas i dont hit 30* until red line. is there any way that someone at predator can tune more timing at low rpms? and would it help and give me and more power? thanks
Sounds like you are running just fine. Under light load you should notice you get a lot of timing. But under hevy load or WOT it will gradually work it's way up to your max(in high rpm's). As far as ading timing I'm not sure about the predator (they should be able to help you) I know Edit can do it. Yes it can help if you get more timing in the right areas. It's all part of tuning. It could also hurt you if not done right. I'm no expert so ill stop here.
