wideband wiring...
wideband wiring...
First of all I'm not sure if this will actually work or not but here's the scenario...I have my wideband gauge already installed, now I just need to hook it up to my wideband sensor. Is it alright to use the power, heaters, and ground from my stock o2's for my wideband (not using the front o2's anymore, tuning in SD and open loop 24/7)??
There's only one wire coming from my gauge to hook up to the signal from my wideband o2 sensor. I just figured since my stock o2's weren't being used I could use the existing wires for my power etc...
What do you think??
What do you think??
That's how I powered my LC1.
LS1 wiring diagram in this thread:
https://ls1tech.com/forums/pcm-diagn...-1-lc-1-a.html
Follow-up thread:
https://ls1tech.com/forums/pcm-diagn...ontroller.html
More info:
http://forum.efilive.com/showthread.php?t=564&page=8
Follow-up thread:
More info:
