Help,loaded funky tc file to 94 lt1
I dloaded some files off the library site.I couldnt get any of them to work(car would start then stall)then i tried the 94 vette file,the car dont start and the low cooling fan stays on all the time.Is there a way to erase the pcm?
the tunercat wont even read the ecu now,PLEASE HELP!
If you can't communicate with the PCM, you can't change the file. There is no "Erase" procedure. Have you tried resetting the PCM?
Method 1 - unplug the PCM fuse in the cabin.
Method 2 - disconnect the battery.
Try about 15 minutes for each (probably less, but give yourself a safe zone).
Did anything unusual happen during the d/l (reset, power loss, open door, roll down window, etc.?)
BTW, car starting and then stalling is normal for the first few attempts, as the PCM resets itself and takes a bit to relearn things. Just an FYI.
What part of Indiana?
