ls1 ecu wiring schematic?
Anyone know of any online photos of the wiring schematic for an ls1 ecu from a 99+camaro or something similiar?
I want to learn if I can rig one up to my gen 1 sbc to control fueling strictly, not ignition.
LS1Tech Sponsor
There are schematics on this site just do a search. To answer your question though, you are going to need a crank signal to get the injectors to pulse. With a distributor I would assume you would need to condition the reluctor signal to read what a 24x or 58x crank signal outputs. I am sure you could do it, I have seen a kit out there that does it with an accel dual pick up distributor.
Interesting......
Interesting......
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
I could use eficonnections setup
http://www.eficonnection.com/eficonn...n_Gen1_SBC.htm
Would their be any interference not using a cam signal since I wont need it for spark? maybe it will just pop a code I could delete?
LS1Tech Sponsor
I dont beleive the you need the cam signal to make that work.
__________________
Ebay Store
Ebay Store
