LT1 tuners in here
Old 12-01-2009, 01:06 PM
FASTFATBOY's Avatar
Default LT1 tuners in here
LT1 tuners, on a 94 ECM can you tune individual cylinders on this ecm? As in timing and fuel under WOT?
Old 12-01-2009, 01:16 PM
matt_paco2010's Avatar
Not timing, but you can adjust the fuel to each cylinder, under cylinder balance. Be careful with this though
Old 12-01-2009, 04:06 PM
FASTFATBOY's Avatar
Yeh I found a LITTLE info on it, I need to riched the 4 corner cylinders as they are lean(er) from the Super Vic.
Old 12-03-2009, 01:42 PM
9-Second Club
Ed Wright's Avatar
You can make individual cylinder fueling adjustments at idle, and part throttle up to 80% throttle angle. I can raise that to 99%, but not 100%.
Not a big deal to lower the TPS to show 98% at WOT. What are you using for individual cylinder air/fuel data?
