Can I swap the rear O2 sensors with the fronts?
Old 12-16-2003, 10:58 PM
frcefed98's Avatar
Default Can I swap the rear O2 sensors with the fronts?
I want to see if it is my O2 sensors that are causing my "hesitation" before I send the PCM out.
Thanks,
J
Old 12-17-2003, 02:15 AM
etc
Guest
Posts: n/a
don't know , but if the plugs are the same i would call the auto parts store and see if it's the same part #. if so, i don't see why not.
Old 12-17-2003, 07:31 AM
Bink's Avatar
Thanks,
J
It's done all the time with Vettes and LongTube Headers - I did it with mine when I was running closed loop. Plugs are different . LG Motorsports has plug adapters. FWIW.
joel
Old 12-17-2003, 10:54 PM
SS SLP2's Avatar
yes will work at any position as long as the wires are long enough may need wire extentions ( may order extentions from most sponsors)
Old 12-18-2003, 07:54 AM
onehardmaro's Avatar
I have done it. Didnt need extensions either. If the front o2 is bad and you put it on the rear it will throw a light but will not effect performance.
