boost with stock e38ecm/maf
srry if its been asked before,, whats max safe boost i could run with out getting a tune..mpt70,stock ly6, iv heard of genIII motors running low boost on stock ecm's using maf,,
lator on i will add 60lbs injectors ,duel walbro,and sd tune,, but right now just wanna run it stock till i collect parts..
so in other words what willstock maf support?
thanks..
thanks..
LS1Tech Sponsor
About 1-2lbs, the timing is far to aggressive even though it will fuel it fine to 5 or so with the stock maf/pe table.
The maf will support big power, as long as the intake tube that it is in is designed properly. I have dealt with a couple turbo "kits" that give maf readings that bounce 10lbs/min at WOT on the 2010' Camaros.
thanks man,, appreaite it,, now what if i sent the ecm out to mail order tune,
i dont really trust mail order tune tho..
i only want to run 10psi.. its in a chevelle, just want to see my options..
