cost of fast management?
Restricted User
No you dont need to use Edit, I believe. I am not sure on our PCMs but my friend Dakota is running a FAST system, and that thing is nice. It sucks to setup appearantly if you have no baseline. But, if you do have a base its awesome. Instead of trying to figure out, or doing a bunch of math, where your timing is bein pulled or needs to be, you scroll across your logged run and it hilites it for you. As well as other things.
LS1Tech Co-Founder
I have a FAST system on my car.
Here is the long answer:
-Yes you can put a FAST sytem on an LS1. I am running a bank to bank setup.
-Check with Cartek.net on the cost
-To run the FAST as a standalone, no factory pcm, you would need an external crank trigger.
-I am running a FAST with an adaptor box from Cartek. I am controlling fuel and VE thru the FAST, but not timing.
-FAST is coming out with a crank signal adaptor that will allow us to control timing thru the FAST system... which is the most ideal.
