edit diagnostic file help
Guest
Posts: n/a
does anyone know if a non electronic throttle motor uses "dtc1514,dtc0101, max air etc" at all ? the edit tutorial leads me to believe not.will additional air from s.c trip " high maf fail mhz" ? any reason not too raise value. also which diagnostic tests to set ses are relativly safe to toggle off. or if easier which too leave on. thanks e
