M6 PCM in an A4?
You cannot tune a flash file to change the type of trannie the flash has for LS1edit has no control of changing trannie type
it has to be done by changing the Vin # in the PCM and then flashing it with a tech II or a Ease/GM SPS flash reprogrammer with a GM flash with the correct trannie type that will be used.
