knock warning system?
Anyone have an idea on how to build a knock warning system? . . . I'm using bigstuff3 to tune a turbocharged ls1. This tuning system has no way of reading the knock sensors. I want to build something similar to the turboxs knock lite. I want to use stock sensors. I need to know what the a/c voltage thresholds are in the stock ecu. I think I saw its less than 1vac max output from the sensors. Any ideas or info would be great, thanks
You may try to contact John directly; seems like Mightymouse's BS3 box has a knock sensor add on, or at least, one of his previous boxes did... I'm almost certain because I remember asking him about the cost of it.
If the stock PCM is still there, you could use it to look at the sensors.
