ls3 map question with 98
Ok i have a 98 pcm and i have a ls3 map sensor, i need to change the values in the map scale but they are not there like they are in 2010 camaro file. So does this mean i am screwd and need to make the stock map sensor work somewhere ? Thanks
Just use the stock 98 MAP sensor. You can't adjust the offset and linear in that setup to be able to make use of the unit from the LS3.
You MAY consider using a 98 2-bar SD OS (if you are considering SD) even though you aren't boosted. You can setup the LS3 MAP and you get full use of a primary VE (no secondary in the custom OS) as well as the ability to properly use both low and high octane spark maps.
ok well i will just get the stock pig tail and the stock 98 map and make it work in the ls3 intake then probably fit it into the hole if its to small make a spacer to put inside with it.
And yes my car is in SD. But what i plan on doing is just switching out pcms from mine to a 99 and newer so i don't have to worry about anything from now on and can do real live tuning. Well thats what i will do then
